Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate roof plugin » » » » Post: Re: Generate roof plugin |
Print at Sep 24, 2026, 1:08:53 PM |
| Posted by dorin at Dec 23, 2023, 7:14:46 AM |
Re: Generate roof plugin Probably I misunderstood again. For this purpose I've made an option in AutoDimensioning plugin, roof projection. To modify this in 3D not only in 2D I try to do in the future for this plugin. In AutoDimensioning wasn't simple to identify the exterior walls and set the build area or roof projection. More than a half of the code is dedicated to this features. The GenerateRoof it is already huge and I don't think it is useful to make it heavier adding something which already exist and work. My yellow room is generated in this way. Then you could make fine adjustments even to add/remove points where you need. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 24, 2026, 1:08:53 PM |
