Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Hexagon buildings roof question. » » » » Post: Re: Hexagon buildings roof question. |
Print at Sep 24, 2026, 3:37:35 AM |
| Posted by Peppyy at Dec 31, 2023, 8:42:09 PM |
Re: Hexagon buildings roof question. The first thing I did was to install the advanced editor and align the building to 90 degrees. I played with a separate model for a while before I created a new one with proper wall heights. https://ibb.co/KszL67G Once I did that I built rooms, one for the front pitch and one for the back. They were larger on the outer edges and centered on the roof-line. I used roof generator setting the elevation lower than the center average height of the wall, made the roof 5-1/2" thick and brought the angles as close to flat as I could and still edit it. My results are pleasing to say the least. https://ibb.co/L92h5YD I then added a texture to make it stand out. Thanks so much to both of you for all your help. I am sure I will have more questions, I promise will do my research first. ---------------------------------------- Who said you can't do it. I don't listen to Who anymore. |
Current timezone is GMT Sep 24, 2026, 3:37:35 AM |
