Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Auto-crashing file » » » » Post: Re: Auto-crashing file |
Print at Oct 6, 2026, 12:56:09 PM |
| Posted by Puybaret at May 23, 2010, 10:29:39 AM |
Re: Auto-crashing file You can always ask and I'm not against Autosave. ![]() But if saving is simple on a technical point of view (saving already exists and programming a timer isn't difficult), it's more complicated than it looks like on a user interface point of view: - When autosave should be run? Always after a certain period of time, even in the middle of a user input? Only between inputs? Then what is considered as an input? - What feedback should be given to the user? Should a blocking save dialog box should appear? Or should a message appear in a status bar (then I'll have to create a status bar)? Or no feedback at all (the user could guess it was saved from the modified info in the title bar)? - If there's no blocking save dialog box, what will happen if saving fails or if the user request to save while a saving operation occurs in a background task? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 6, 2026, 12:56:09 PM |
