Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Wallapproach configurable? » » » » Post: Re: Wallapproach configurable? |
Print at Sep 30, 2026, 5:13:59 PM |
| Posted by waxweazle2001 at Jan 10, 2024, 9:34:39 PM |
Re: Wallapproach configurable? OK, it took a few reads, but I think I understand. You want the left side of the highlighted wall to be aligned with the left side of the short outer wall below it. The walls are different thicknesses. Because the walls are positioned based on the center line of the wall, it is tricky to make them align. You have two choices. 1) Zoom in to max magnification and nudge the inner wall left and right with the arrow keys until they are visually aligned on the left. (Shift+arrow jumps a greater amount). 2) Do some math. Outer wall x - (Outer wall width / 2) = Outer wall left side xThats exactly what I mean, so I will try this. But the last thing with Math I don't understand. Is this for the Coordinates or the measurements? I Changes the coordinates but then the outer Wall moves with because it is locked in the Middle. |
Current timezone is GMT Sep 30, 2026, 5:13:59 PM |
