Print at Sep 29, 2026, 3:24:34 PM
Posted by dorin at Jan 16, 2024, 6:53:11 AM
Re: roof plugin is grayed out!?
I'm not an architect but usually I draw walls (structure) first and insert the rooms after.
The "rooms" are 3D objects wile has high (the level high) and ceiling.
I want to get a roof for a building, not for a room
1. You could use AutoDimensioning to get the roof projection (a room biggrin )
Suggestion: Read also at the binging of tread to see how it work.
2. Select the roof projection and use GenerateRoof.
...without creating a single room...
And how you calculate the area?? Manually??
I'm still not an architect but a plan need to have dimensions and surfaces for every closed space.
