Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Staircase generator plug-in » » » » Post: Re: Staircase generator plug-in |
Print at Sep 23, 2026, 12:35:11 PM |
| Posted by architectech at Jan 16, 2024, 7:17:44 PM |
Re: Staircase generator plug-in Hi: Thanks for your insights. I copied and saved your post for study, and read thru a couple of times. --One question directly: you wrote "Last stair elevation 2.70" I think that elevation in SH3D always means the bottom of an object. I need last (highest) stair TOP to be 2.70. So, if I got it right, Last stair elevation should be 2.70 minus the height of one stair. Please, tell me, if that is so or not. --The Multiplyer plugin approach for concrete staircase could work, but of course, I need the handrails. And mostly I need the very conservative U-shaped-with-landing-in-the-middle (two-flight) staircases, which I can't see how to do with the multiplier. There seems to be columns for handrails, but no handrails. (Also, I could not find concrete texture.) --As an architect, I actually drew lots of staircases with pencil on paper. Then went over to ArchiCAD. Now my free access ended, hence I am working with SW3D. I am doing visual plans only nowadays. --Please, tell me how you "custom create" your staircases, if it is not a trade secret. Best wishes Erik |
Current timezone is GMT Sep 23, 2026, 12:35:11 PM |
