Print at Sep 30, 2026, 5:20:20 PM
Posted by Keet at Jan 20, 2024, 12:33:35 PM
Re: Apartment project with lighting by invisible hemispheres. I continue advertising
Did you make all sides of the box except the front invisible before exporting?
After export/import the 'box' should have a depth of 0 so I don't see how the renderer can process that.
Also, the box is square and the white line is around the person so I don't see how the box itself can be the cause of the white line. My guess is that it is the fading to transparent in the picture.
Try it with a picture of a black square on a transparent background. The square shouldn't have a fading outline but go directly from black to transparent from one pixel to the next. Then see if the white line persists. If not then the fading to transparent is the cause of the white line.
If the fading is the problem then the picture must be edited to eliminate that fade. The picture on its own will look a little strange but once on the box and in the project the white line should be gone.
