Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: No hole in the slab for staircase » » » » Post: Re: No hole in the slab for staircase |
Print at Oct 4, 2026, 6:21:20 PM |
| Posted by architectech at Jan 20, 2024, 6:50:32 PM |
Re: No hole in the slab for staircase Hi Keet: Thanks for the exhaustingly detailed explanation. As usual, your input is a study object for me… –I don't know about import/export. I just made a staircase from the "Staircases" item, clicking on the normal left-side SH3D menu, then choosing "Add to home" in the "Furniture" menu. After it I tried also with the "Generate staircase" plugin, with the same result. As I was reading your post, I thought that perhaps it is also a way, if I would create the slab from several boxes, so that the space for the staircase would be let open. We will see… I will try everything. |
Current timezone is GMT Oct 4, 2026, 6:21:20 PM |
