Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Apartment project with lighting by invisible hemispheres. I continue advertising » » » » Post: Re: Apartment project with lighting by invisible hemispheres. I continue advertising |
Print at Oct 3, 2026, 9:44:09 PM |
| Posted by GaudiGalopin3324 at Jan 21, 2024, 6:53:07 AM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising as expected, sitting people turn out to be difficult. I realized that this model works like a film stained glass window, so the figure on the windowsill is very bright from the lamp from the street. I couldn't remove this extra brightness. On the contrary, the man in the chair turned out to be too dark at first. I placed a 10% elongated sphere behind his back, highlighted it too brightly. The problem with space was solved simply - I made an additional left leg of the foot-knee separately and moved it forward with a slight increase. But at first, for some reason, it turned out to be very dark. I also had to highlight it from behind with a vertical sphere and did not guess the power . I put a "prosthesis" out of the box behind the sphere so that it would give shade to the chair, as if from the foot. But something didn't work out. In general, I am not happy with the result at all, there are many different incomprehensible effects that cannot be easily solved. But you can put people on chairs, only they will look worse than those standing next to them. |
Current timezone is GMT Oct 3, 2026, 9:44:09 PM |
