Print at Oct 5, 2026, 6:51:53 AM
Posted by Puybaret at Jan 26, 2024, 4:10:13 PM
Re: Zoom doesn't work with scroll wheel, pan only pans vertically
You don’t have the choice between Ctrl and Shift to zoom. Only Ctrl + mouse wheel will work (or command key + mouse wheel under macOS) if you place the mouse pointer on the plan.
About spanning step, you should probably adjust your mouse wheel in system settings. There’s no other setting in Sweet Home 3D anyway.
