Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Auto-crashing file » » » » Post: Re: Auto-crashing file |
Print at Oct 6, 2026, 1:29:30 AM |
| Posted by db4tech at May 25, 2010, 9:43:38 AM |
Re: Auto-crashing file Gentlemen: Hi Hans,I loaded the file on my laptop and it crashed so hard that even Windows shut down. As to possible hardware issues: - Laptop: Windows Vista, AMD duo-core, 2 GB of memory; I never had any trouble using SH3D (apart from all kinds of random problems and/or crashes) - PC: Ubuntu 10.04, Intel duo-core, 4 GB of memory (of which Ubuntu only reports 3.3 GB), Intel 950 graphics chip (since updating drivers with Ubuntu 9.10 no serious SH3D problems) I'm pretty sure the hardware isn't the problem. Maybe it's Ubuntu, in that case the problems should gradually go away as new updates are delivered. Maybe it's SH3D and then I'm sure the problems will go away if and when it becomes clear what causes them. Emmanuel: On Sunday and Monday the PC crashed at least 5 times, I can post the log-files if you're interested. Hans With you mentioning about your Linux system only having an Intel 950 chip (please can you specify what graphic card your laptop has) I think it could still be a graphics card problem. If it is helpful I have found Sweet Home to be incredibly stable, the only time I had a problem was trying to show someone a model I had created on their system which refused to display, they were also running an Intel graphics card. I tried opening your original model again and am able to walk around your building without any problems or crashes, I can produce some renders if needed? By chance do you have an Nvidia graphics card you could try in your Linux system? To try and help isolate what may be causing the problem I have removed all textures from this version of your model, which should take a lot of strain off your GPU, please can you can try loading it to see if it still crashes. Thank you. House with double roof (no textures) db4tech |
Current timezone is GMT Oct 6, 2026, 1:29:30 AM |
