Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Roofs » » » » Post: Re: Roofs |
Print at Sep 26, 2026, 2:58:38 PM |
| Posted by Keet at Feb 3, 2024, 5:09:24 PM |
Re: Roofs Assuming you already installed the Generate Roof plugin check out this topic describing dormers and integrating Velux windows: https://www.sweethome3d.com/support/forum/vie...ad,11330_offset,190#60535 Don't forget to install the special window library Dorin created to integrate the windows in the roof. That the roof is above 2 levels doesn't make a difference. After generating it's another object you can move to another level or give a different elevation. That way you should be able to place it where you need it. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 26, 2026, 2:58:38 PM |
