Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Roofs » » » » Post: Re: Roofs |
Print at Sep 28, 2026, 10:00:30 PM |
| Posted by Keet at Feb 4, 2024, 2:05:04 PM |
Re: Roofs I assume you mean the Generate Roof plugin. To generate a roof the plugin needs a room that is selected. A roof is generated using the points of the room. After the roof is generated you can also select the generated roof to restart the plugin to make changes to the roof, the room is no longer needed unless you want to use it again to generate a new roof. You can save the room in another level that you make invisible since it is probably a room that is not used as the floor of the house. The room to generate a roof usually extends outside the walls to get an overhang of the roof. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 28, 2026, 10:00:30 PM |
