Print at Oct 8, 2026, 2:41:39 AM
Posted by [email protected] at Feb 13, 2024, 8:21:20 PM
Re: How to define multi-level hinge and rail of 3D model
I explain the logic of my...ghost
First I drill the wall with a position fixed to the dummy (exported in that position re-imported as a window to drill the wall), I make the walls transparent or partially transparent and export.....
When I re-import it the wall will be perforated and of the desired transparency.
I export the used dummy object and edit the MTL file using the d parameter 0.???????????? on the parts to be made semi-transparent.
I reimport everything, I position the dummy (imported as a window) on the surface of the wall in correspondence with its hole... and I move it slightly to one side to give the sensation of a movement OUT of the wall....... I reimport and reimport .....now a mannequin moves as if it had come out of the wall to which it is attached.
This is my idea....do you think it could work????
Greetings
