Print at Sep 24, 2026, 6:22:11 AM
Posted by MartinH81 at Feb 14, 2024, 7:33:05 PM
Re: Generate roof plugin
Dear dorin
Thank you again. I installed the library and it allows me to insert velux windows (I guess that is the name for the windows who are in line with the slope of a roof).
I have two additional questions. This roof has an elevation of 5.5m above the ground and it is actually 6.05m high. When I re-generate the roof I can set the correct elevation right from the start, but I miss were I can actually set the height right from the beginning. Then I have to raise the roof to the correct height after its generation, what changes the slope of the roof, but not the height or slope of the window. Is there a way to either get the right height from the start or otherwise to keep the window aligned to the roof?
And the other questions concerns dormers. I have seen some advice how to build dormers with walls reused as furniture and so on, but when I have a dormer window like that and I look through it from the outside, I just look at the roof. My first guess would be now to use the roof-window library and get a window of the size of the dormer in order to cut out that piece of the roof, but perhaps there is a better way for this. What would you say?
