Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Autosave 3djs » » » » Post: Re: Autosave 3djs |
Print at Sep 23, 2026, 3:55:17 PM |
| Posted by adizanni at Feb 15, 2024, 10:29:27 AM |
Re: Autosave 3djs Hello thanks Emmanuel for the rapid answer, Yes using the delete of java.io.File. I'm currently working in Eclipse on Windows and deploy Tomcat as a Target runtime, not clear which permission I have to look into. The properties of the Homes folder inside WebApp give only the possibility to set or unset "ReadOnly" and it is unset (I can create and edit existing files). What I'm trying to do: I'm the developer of this card : https://github.com/adizanni/floor3d-card in Home Assistant (home automation software), I'm trying to build a Home Assistant add-on to encapsulate SweetHome3D inside the Home Assistant frontend and also migrate my existing SweetHome3D plugin: https://github.com/adizanni/ExportToHASS to JSP. By the way, I'm a big fan of your work.... Thanks in advance for the support. Andrea |
Current timezone is GMT Sep 23, 2026, 3:55:17 PM |
