Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to define multi-level hinge and rail of 3D model » » » » Post: Re: How to define multi-level hinge and rail of 3D model |
Print at Oct 3, 2026, 9:47:03 AM |
| Posted by [email protected] at Feb 15, 2024, 11:43:15 AM |
Re: How to define multi-level hinge and rail of 3D model Keet One last thing about this post. I tried the cylinder method. Real easy. To the advantage of my object, in addition to visually bringing the transparent view of the hole on the wall before exporting. it also does it visually for any solid positioned inside or even partially supported by the wall......exporting this object together with the wall will position it where it was visually placed. In fact it is the same thing as the cylinder without having to make the materials of the cylinder invisible, with my object you just position yourself, nothing else Furthermore, the thing would be repeated regardless of the form the original exported room had If we hear back, it will be in another post. Greetings |
Current timezone is GMT Oct 3, 2026, 9:47:03 AM |
