Print at Sep 23, 2026, 4:35:27 PM
Posted by adizanni at Feb 16, 2024, 8:18:33 PM
Re: SweetHome3DJS - Porting plugin - ARM architecture support
To explain better what I'm doing:
  • Building a container that will run SweetHome3D JS with Tomcat
  • Encapsulate the home editor inside a Web Site that manages the sh3d files
  • Provide an export feature that replicates the function of my plugin ExportToHASS which is similar to Export To Obj but preserves the object names across exports
  • Deploy the container as Home Assistant add-on
I was assuming that the SweetHome3D could run headless. It seems that the Home class and Homerecorder class can run headless, but as soon as I reference the J3D class, the exception is raised for lack of a display. This is a pity as I only use J3D to serialize the home into Waterfront format (based on a modified ObjWriter class). This is an operation that wouldn't require any visualization.
