Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: SweetHome3DJS - Porting plugin - ARM architecture support » » » » Post: Re: SweetHome3DJS - Porting plugin - ARM architecture support |
Print at Sep 23, 2026, 4:35:31 PM |
| Posted by Puybaret at Feb 16, 2024, 9:08:23 PM |
Re: SweetHome3DJS - Porting plugin - ARM architecture support Sweet Home 3D can run headless if you set the Java property java.awt.headless to true (which is probably the default value in Tomcat) and set the Java property j3d.rend to noop. You may even need no library in that case but I’m not sure. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 23, 2026, 4:35:31 PM |
