Print at Oct 4, 2026, 5:36:53 PM
Posted by Keet at Feb 17, 2024, 9:10:27 AM
Re: Not perpendicular triangle
You can rotate the triangle along the X and Y axes. If you need to rotate both X and Y, first set the X, export/import, and then you can set the Y.
Of course you can also use the Generate 3D Shape tool under the Tools menu to generate any shape with 8 or less points. (That's the ShapeGenerator plugin if you haven't installed that yet.)
