Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: page size / sheet size image centering » » » » Post: Re: page size / sheet size image centering |
Print at Oct 4, 2026, 1:11:00 PM |
| Posted by Keet at Feb 17, 2024, 9:24:32 AM |
Re: page size / sheet size image centering Uhm, the main purpose of PDF is to have a predefined format independent of the printer. The only thing required is that a PDF created for A4 is printed on A4 otherwise it scales, what printer doesn't matter although you still can print it on other paper formats. In LibreOffice I can set any paper size I want for a document and when I export to PDF that paper size is used for the pdf. I don't need to have a printer installed at all. When you select PDF as your printer you should be able to set any size you want because that 'printer' can handle any size. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 4, 2026, 1:11:00 PM |
