Print at Oct 3, 2026, 8:42:08 PM
Posted by Keet at Feb 18, 2024, 8:00:15 AM
Re: page size / sheet size image centering
When you install a PDF driver you actually install a printer, although not a physical one. A physical printer is limited to what sizes it can print and what the firmware allows for other options like scaling and setting margins. A PDF printer doesn't have those limitations so it fully depends on what is programmed in the PDF driver. You just have to find the right one for you.
Check here for some free PDF printers:
https://pdf.wondershare.com/pdf-editor-mac/free-pdf-printer-for-mac.html
Find the one that offers the options you need although there will be very little difference between them I suspect.
When you select the PDF printer from whatever software you use, it acts like any normal printer so it should also show the options you need.
This means that in the preferences of Sweet Home 3D you can alternatively choose to select a printer (the PDF one you installed) instead of using the option "Print to PDF".
Remember: it's like like you attached a normal physical printer so keep thinking about that when you use the PDF printer. It just doesn't print to paper but to a PDF file.
