Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Draw False Ceiling » » » » Post: Re: Draw False Ceiling |
Print at Oct 2, 2026, 5:08:01 AM |
| Posted by Keet at Feb 19, 2024, 11:30:51 AM |
Re: Draw False Ceiling That's easy: export the floor to an object and import it. This will give you an object that you can elevate to the false ceiling height in exactly the same shape as the floor. Make sure that the floor you export is on a level with level elevation >0 and switch off display ceiling. After import you can adjust the height like any other object. It is initialy created with the floor thickness as the height. Using a floor also makes it easy to create a hole in it if you need it somewhere: use an object that is a staircase that will create the hole before you export the floor. edit: "floor" == room ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 2, 2026, 5:08:01 AM |
