Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to make a mirror surface » » » » Post: Re: How to make a mirror surface |
Print at Oct 3, 2026, 12:16:14 AM |
| Posted by Puybaret at May 27, 2010, 10:50:56 AM |
Re: How to make a mirror surface In the current version of Sweet Home 3D, a part of a 3D model is treated as a mirror if the name of that part starts with sweethome3d_window_mirror. As the way to name a part differs from one format to the other, here's the steps to follow if you want to name mirror surfaces modeled with a texture image in a 3D model at any format: - download the mirror model you want, - import it in an empty document in Sweet Home 3D, - export the document at OBJ format, - edit the generated MTL file and find the line(s) starting by map_Kd and followed by the file name containing the mirror texture image found in the same folder as OBJ and MTL files, - in the lines that precedes that map_Kd line, find the first line starting by newmtl and note down the material name that follows newmtl, - now, edit the OBJ file and find the line(s) starting with usemtl and followed by the material name of the mirror you found in the MTL file, - in the g line(s) that preceding the usemtl line(s), add the sweethome3d_window_mirror text in front of the piece name following the g letter, with no space between sweethome3d_window_mirror and the piece name, - save the OBJ file, - import the saved OBJ file in your home and check if it's treated as a mirror with the two best qualities in the Create photo dialog. I hope you can make it. The first time will be probably difficult, but once you understood the logic, it's quite easy. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 3, 2026, 12:16:14 AM |
