Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: SweetHome3DJS - Porting plugin - ARM architecture support » » » » Post: Re: SweetHome3DJS - Porting plugin - ARM architecture support |
Print at Sep 23, 2026, 7:40:15 PM |
| Posted by adizanni at Feb 20, 2024, 11:09:23 PM |
Re: SweetHome3DJS - Porting plugin - ARM architecture support Thanks again: for the persistency architecture I will need to dedicate more time, for the moment I'm resolving with a "not so clean" folder linking. Of course these are mainly solution that will stay local, protected by the home network, but I prefer not to open breaches and vulnerabilities, as much as possible. This brings me to another question, home assistant can shield the add-ons using an internal proxy that rewrite the URLs. All the portal jsp pages are properly rewritten but when I open the sweethome.jsp it seems that all server calls are not getting rewritten and target the original URLs. It is a complex problem, I'm not expecting an answer or an analysis from your side; maybe you have already stumbled upon the issue and got a solution. The rewritten leading URL parts are passed on by the proxy via a header field. I have another question related to your previous answer: how can the end user load additional furnitures and object to the catalogue ? There seem to be no function to achieve that, there is one to import texture though. Thanks in advance for your support. Andrea. |
Current timezone is GMT Sep 23, 2026, 7:40:15 PM |
