Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: getting the level on levels » » » » Post: Re: getting the level on levels |
Print at Oct 3, 2026, 4:34:29 AM |
| Posted by Keet at Feb 21, 2024, 2:53:13 PM |
Re: getting the level on levels It probably has to do with the numbers you are using. Read up on levels here: https://sweethome3d.com/userGuide.jsp#addingLevels and here for levels below 0: https://www.sweethome3d.com/blog/2022/04/21/h...basement_to_a_design.html Floor thickness is exactly what it says: the thickness of the floor. The lowest level has a floor thickness of 0. You can see that because the setting in the modify level dialog is grayed out. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 3, 2026, 4:34:29 AM |
