Print at Sep 23, 2026, 7:05:51 PM
Posted by Puybaret at Feb 22, 2024, 2:29:47 PM
Re: SweetHome3DJS - Porting plugin - ARM architecture support
I'm not sure at all but did you set the URL base used at different places in application initialization, so it correctly indicates the redirection you mentioned?
Even though I found a way to import a 3D model in the Mobile version using existing code, importing additional furniture is not completely programmed. The Import furniture wizard and saving imported furniture in preferences is missing in current version.
