Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 7.2 » » » » Post: Re: Sweet Home 3D 7.2 |
Print at Sep 23, 2026, 4:21:12 PM |
| Posted by Daniels118 at Feb 24, 2024, 12:13:35 PM |
Re: Sweet Home 3D 7.2 @sbj007 My plugin uses the same method used by SH3D to get the output folder, it is the result of a computation, so it may vary depending on the environment. @snmavronis Btw, the plugin and the output redirection method from the command line are mutually exclusive, so only one should be used. @snmavronis, @PUYBARET The specific problem it is described here: https://bugs.openjdk.org/browse/JDK-8305072 and a possible workaround that may be applied without waiting for a bug fix is here (but I'm not able to test it): https://github.com/apache/netbeans/discussions/6361 It would be nice to see which files are actually breking the file dialog. |
Current timezone is GMT Sep 23, 2026, 4:21:12 PM |
