Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to make a mirror surface » » » » Post: Re: How to make a mirror surface |
Print at Oct 3, 2026, 7:24:47 PM |
| Posted by RUSSIAN at May 27, 2010, 2:40:36 PM |
Re: How to make a mirror surface Great you found out how to do it even when there's no texture image for the mirror part! Yeah, there was only 1 texture (wood) in that file. When I exported it to obj, there was wardrobe_piece_1_1.jpg , but .mtl file had also mentioned materials piece_1_41, piece_1_61 and piece_1_53, and there weren't map_Kd line for these materials. I copied wardrobe_piece_1_1.jpg to *_1_61.jpg, *_1_53.jpg and *_1_41.jpg, and added the map_Kd lines to each part of .mtl file. Then I draw a gray rectangle in Paint, and save it like "mirror.jpg". Then I tried to found, which of the materials is for what parts of wardrobe (just renamed mirror.jpg to wardrobe_piece_1_41.jpg and so on, and imported furniture after every try). And the last part, was changning the .obj file for mirror material, as you recommended. May be I did some excessive work, but the result is OK. Thanx for the main idea! |
Current timezone is GMT Oct 3, 2026, 7:24:47 PM |
