Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Photo-video rendering plug-in » » » » Post: Re: Photo-video rendering plug-in |
Print at Sep 23, 2026, 4:20:47 PM |
| Posted by enkonyito at Feb 28, 2024, 3:16:36 PM |
Re: Photo-video rendering plug-in I'm joining, I'm having the same problem and I'm looking for a solution too. Rendering with light bodies. In the designs I made a few years ago, the light panels appear strangely on the render images, whether visible or invisible, or of any shape, a small ball of light or a dark circle appears in the middle in each case. Of course, the sh3d version changed in the meantime. Now 7.2 and the latest plugins. ![]() https://www.dropbox.com/scl/fi/gmgj75b57qihr8...5y34m23gc2w7n85h&dl=0 What can I do like this? 1. Should I go back to version 6.6 (on one of my PCs), but I don't remember what light kit is needed? 2. Should I replace the lighting bodies one by one with the new verzo lights (light panels), which is not a small job? 3. Or something else? Now I'm at a loss, is there a good solution for this? Thank you! @Karoly If you want to keep the old light panels (not using the lightSourceMaterialName# property) from your previous projects, you must use a compatible version of the plug-in, i.e. before PhotoVideoRendering-2.5 . Even though it works with Sweet Home 3D 7.2, you won't benefit from the latest fixes or improvements. ---------------------------------------- EnkoNyito |
Current timezone is GMT Sep 23, 2026, 4:20:47 PM |
