Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Apartment project with lighting by invisible hemispheres. I continue advertising » » » » Post: Re: Apartment project with lighting by invisible hemispheres. I continue advertising |
Print at Oct 2, 2026, 9:02:25 PM |
| Posted by Keet at Mar 1, 2024, 7:27:59 PM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising You might find this site helpful: https://www.colorhexa.com It has all color codes for use in your objects. You can enter a name like "gold" or "ivory", or a #hex code in the search box to find your color. It also supplies the XYZ codes for the color, the codes as used in MTL files. No need to convert a #hex code to those numbers if you want to enter a color code directly in a MTL file for the Ka value. The site also provides alternatives, colors that are slightly different but could be a better fit for your objects. And finally it also shows scales with different shades, tints, and tones for a color. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 2, 2026, 9:02:25 PM |
