Print at Oct 4, 2026, 5:19:30 PM
Posted by archibaldtuttle at Mar 4, 2024, 2:59:41 PM
Re: Is there a way to color 2D view
@puybaret
so i tried rooms and making polygones out of polylines for just those reasons.
I succeeded in making a rectangular polygon the same 2D size as a wall and coloring it, however the address to the Z dimension is clumsy and it only shows up in the bottom of doorways. I tried making the polygon taller than the wall but that didn't help. I tried moving it to a higher layer and making all layers visible but the layer with the polygon only shows the polygon even though all layers are "viewable" and other layers that seem to show other layers do not display the polygon (or they display it in a way that it is covered by the walls even though I set the layer elevation higher.
sleepless in seattle, well in smithfield. couldn't log in for a while to respond. turns out i had to clear my cookies.
who knew.
