Print at Sep 30, 2026, 11:41:25 PM
Posted by Keet at Mar 5, 2024, 1:59:03 PM
Re: Automatic dimensions addition
Trying out plugins is very easy if you first install the plugins manager: https://sourceforge.net/p/sweethome3d/plug-in.../PluginManager-1.5.3.sh3p
Once that is installed you can just select a plugin you want to add, update, or remove.
You can read more about it here: http://daniels118.altervista.org/sh3d/pluginmanager/
There is no plugin to color walls in the 2Dview but there are a lot of other useful plugins. You should at a minimum install the advanced edit plugin and you will probably want the Roof and Staircase generator plugins too. The Pan3DView plugin gives you a better 3Dview experience.
