Print at Sep 29, 2026, 4:48:04 PM
Posted by Keet at Mar 6, 2024, 7:13:57 AM
Re: Custom 3D Model being imported without texture
What file format are you importing? (OBJ/MTL, 3DS?)
Usually the problem is that the path reference to the textures is wrong or there simply are no textures.
With an OBJ/MTL file you can check the MTL file. The texture references on the map_Kd lines tell you where the textures are expected to be found. Make sure the textures are at the listed location. It's common to have the textures in the same directory as the OBJ/MTL file and no path reference in the MTL file.
If there are no textures you should check that the program you use for creating the 3D models (Blender?) exports the textures along with the mesh file.
