Print at Oct 2, 2026, 9:06:43 AM
Posted by Keet at Mar 6, 2024, 2:00:55 PM
Re: Custom 3D Model being imported without texture
Check your export from GLB to OBJ. You should have an .OBJ file, a .MTL file, and one or more texture image files.
If the MTL file is missing you won't have any meterials, if the texture images are missing you won't see any textures.
Both the OBj and MTL files are just text files you can edit with a plain text editor. In short, the OBJ file is the mesh, the model itself. The MTL file is the materials file where the different materials are defined.
If you do have the MTL file and the texture images, check the OBJ file Close to the top in the OBJ file there should be a line "mtllib ????.mtl" where ???.mtl is the name of the MTl file you got with the GLB conversion. If that line references a non-existing MTL file you will not have any material, i.e. textures or predefined colors.
