Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: problem to 3d view » » » » Post: problem to 3d view |
Print at Sep 28, 2026, 2:29:20 AM |
| Posted by [email protected] at Mar 7, 2024, 7:36:39 PM |
problem to 3d view Good evening everyone, especially Keet who I have already bothered with problems, to which he has given excellent solutions. I hope I chose the right post. Once I had created the "famous" (at least for Keet) EXTERNAL SLIDING DOOR (following his every suggestion) I realized that, apart from the known problem to view of inserting a door/window on a wall not aligned with a rail scrolling (with the same methods listed below), the "door" object when scrolling along its SWEETHOME3D_RAIL_ in 3D view has different behaviors. If you proceed with the opening via a panel (therefore permanent) in effect it also drags "the door/window property" along the rail, not keeping it in the initial position but widening it along the wall in the direction of the movement, which on the contrary does not happen if you act directly on the object in 3D view. It's not a huge problem but it's annoying. I also take this opportunity to ask if there is a method to define ONLY ONE PART of a complex object such as a door/window. Thanks in advance for any advice.s |
Current timezone is GMT Sep 28, 2026, 2:29:20 AM |
