Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: 3D object import issue » » » » Post: Re: 3D object import issue |
Print at Sep 28, 2026, 11:25:42 PM |
| Posted by Puybaret at Mar 8, 2024, 8:51:37 PM |
Re: 3D object import issue I could import your file without problem. If you want to center the TV in its box, you should import it in Blender where you'll be able to edit all the vertices you want, then export it to OBJ format to import it in Sweet Home 3D. Sweet Home 3D isn't able to make such modifications. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 11:25:42 PM |
