Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Apartment project with lighting by invisible hemispheres. I continue advertising » » » » Post: Re: Apartment project with lighting by invisible hemispheres. I continue advertising |
Print at Oct 1, 2026, 5:27:29 AM |
| Posted by GaudiGalopin3324 at Mar 10, 2024, 7:09:38 AM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising now you can proceed to the next step. 2. Create a box with dimensions from the name. Height 1207 cm, width 409 cm, depth 5 cm. Don't be confused by the huge size. Assign our photo to the front surface, make all the others invisible. In the size settings, check the box "keep proportions" and set the height to 180 cm. The remaining sizes will decrease in the right proportion. It is very important for us to maintain the initial proportions so that the beautiful Daenerys remains so truthful and continues, and does not turn into a flounder or a rabbit because of our negligence. The height of the image will be approximate for now, we will be able to adjust it. The human figure has growth parameters, but for example, if a person has a headdress with feathers, a crown on the king, if a hand with a sword is raised up - how to set the correct height? It's very simple!) There are reference points, and these are human eyes. They are located exactly minus 13cm from the top of the head. Therefore, you can always confidently set the correct size of the figure at eye level. For simplicity, you can take the universal height for girls of 163cm (eyes minus 13cm = 150 cm). For men, the height is 178cm (eyes minus 13cm = 165cm). For a person sitting on a chair, the eye level can be set at 115cm. This level may be lower, depending on the furniture and the person's posture. He can sit straight or lean back on the sofa, then you can adjust the eye level to a smaller side (110cm). How do I set this level? It's very simple!) You need to make a reference box of the right height and cut it into the figure without pity. The 150cm high box will be a template for adjusting the size of the box with the image of Daenerys. Keep the proportions of the box and carefully lower the height of the box with the photo so that the eyes are exactly on top of the standard at the level of 150cm. Everything is very simple. for seated figures, this size needs to be meaningfully adjusted. The height of the furniture may be different, for example, for expensive sofas and armchairs, this seat height may be lower than the height of the chair. A chair has 47 cm, an armchair or sofa can have 40-42 cm. The girls on the couch are of different heights. The girl on the left is sitting on her own leg, so she is sitting taller than an ordinary person. This needs to be adjusted with understanding. |
Current timezone is GMT Oct 1, 2026, 5:27:29 AM |
