Print at Sep 26, 2026, 2:35:03 PM
Posted by hansmex at May 28, 2010, 1:38:37 PM
Re: Export as ZIP file?
Emmanuel:
Sorry for not answering before. Yes, the plug-in now works fine. I don't know why it didn't function properly earlier on. Now that the rendering problem from exported problems is solved, creating your own models (furniture, 2nd floor of a house, etc) has become much easier.
Nevertheless... if you want to make your own furniture you have to
a - select the parts
b - click Copy as new furniture
c - copy it with CTRL-V to insert it, then
d - copy it again to a new, empty instance of SH3D,
e - export it as an object,
f - import it as furniture.
So... maybe it would be possible to do it this way:
a - select the parts you want to export
b - select Copy as new furniture
c - the dialog window from Import furniture opens, and follows that sequence to import the selected items.
The only difference would be that instead of asking in which directory to look for the model, the dialog asks you in which directory you want to save the model.
One of the reasons why I want to this to work as easy as possible, is the number of "dialects" in the OBJ format. Every program seems to interpret the rules slightly different. Therefore the best models you can make for SH3D are models made with SH3D itself.
