Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: problem to 3d view » » » » Post: Re: problem to 3d view |
Print at Sep 29, 2026, 3:20:20 PM |
| Posted by [email protected] at Mar 11, 2024, 11:44:19 AM |
Re: problem to 3d view Hi,Keet I will try, making my life difficult, with a French window (antique style double high door and glass panes) with an external shutter and jealousies (therefore different HINGES with independent vertical and horizontal movements). "By-the-way, it doesn't matter at what angle the wall is. A door_or_window snaps into the wall at any angle. It doesn't work very well on a curved wall though." True but in the specific case placing the sliding "door/window" (even yours) at 180° on a 93° wall gives rise to the transparency error. However, the fact remains that the "door/window" has blocked dimensions and therefore if placed (for example only yours but equally mine) on a wall of different depth this involves either the FRAME coming out or the cavity in the insertion wall . To obtain compliance, it is necessary to export the object to the library and re-import it, modifying only its width. |
Current timezone is GMT Sep 29, 2026, 3:20:20 PM |
