Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Doors and windows avoid unwanted deformation- my way mini tip » » » » Post: Doors and windows avoid unwanted deformation- my way mini tip |
Print at Oct 3, 2026, 3:21:03 PM |
| Posted by dorin at Mar 11, 2024, 9:36:42 PM |
Doors and windows avoid unwanted deformation- my way mini tip The unwanted deformation of doors and widows inserted in walls is very old (at least for me). Motivations: All the doors and windows I bought were made of wood, glass, metal and plastic including the handles. All were fixed sizes and none were made of rubber or gum. This was also to be reflected in the house plan. Unfortunately, it wasn't quite like that. Look at the first left door in the picture: ![]() Also see how they are represented in the plan. Let's analyze it. If you like how look the first door skip the rest and read something else. Some unnecessarily explanations: SH3D work with libraries of objects. Every object in the library have a order number and a description of their specific properties writhed in the FurnitureCatalog.properties file. First door, from the DefaultFurnitureCatalog.properties file have this description: id#19=eTeks#door The second, which is pretty similar have this description: id#20=eTeks#openDoor What's the major difference? This: doorOrWindowWidthDepthDeformable#20=false If is not specified, the default is 'true' and is used. At the third door, because it is not quite usual, I've need to set also other properties accordingly with my needs. How I usually solve this? Well, in the most ugly way: Manually! I add this property to every door or window in the Default Catalog and on every imported furniture library. Usually took between one to one and half hour. The demo file is here . ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Oct 3, 2026, 3:21:03 PM |
