Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Doors and windows avoid unwanted deformation- my way mini tip » » » » Post: Re: Doors and windows avoid unwanted deformation- my way mini tip |
Print at Oct 3, 2026, 8:44:48 AM |
| Posted by dorin at Mar 12, 2024, 8:21:49 AM |
Re: Doors and windows avoid unwanted deformation- my way mini tip @Emmanuel You've right! But, without magnetism I have to manually set every door to be in the right position. That mean to have a proper angle of view in 3D and move the door in 2D until the case-frame remain exactly at 1 cm outside the wall (the case-frame thicknesses). It's not impossible but it need a lot of work every time. So, I prefer to work once to set the correct furniture properties (which also is not so simple) and than use it with confidence everywhere. With the last version of FLE this task it is a little more easy. @Keet Unfortunately I'm stuck in the real life. In my apartment I have 7 doors in 7 walls with 10 different thicknesses . but if the difference gets too big it leaves a door/window that doesn't fill the gap Indeed. Exactly that has happened to me (in real life). Well, when I will have some extra money I will buy some extra door frames to complete the gaps.(Not in this life )I've also played with different properties for my doors. Here is one of my Door glass: name#2=Door glass 80 opening As you could see the #doorOrWindowWallDistance#2=4 is commented. In my case was useless while the outer frame stay exactly where I want. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Oct 3, 2026, 8:44:48 AM |
