Print at Oct 4, 2026, 6:53:45 AM
Posted by Keet at Mar 12, 2024, 8:58:51 AM
Re: Doors and windows avoid unwanted deformation- my way mini tip
Fortunately we have all these different options to get what we need anyway we want smile
By-the-way, even with 7 different wall sizes it's simple to create 7 objects with the same door but with a different outer frame. If the outer frame is a simple construcion of three boxes you create one frame and export with the door in it. Simply enlarge the depth of the frame and export again. Rinse and repeat for each wall size.
My outer frames are usually those simple three boxes and beveled borders on the inside and outside. I increase the depth of the boxes, attach the beveled borders and export. Using a separate outer and inner frame makes these adjustments for wall thickness very easy.
