Print at Sep 29, 2026, 7:14:29 PM
Posted by [email protected] at Mar 12, 2024, 5:00:00 PM
Re: Custom 3D Model being imported without texture
as you know, I fill my free time with my experiments.
After I have corrected the opening error of the "jealousies" of the window shutters (it will be sufficient to change the size of the relative Hinge, center it, position it correctly and reduce it to 1 for "jealousy"...I will have to deal with the union of the various objects (and each movement of the same) in a single object (which is not simple and a source of errors and import blocks)....
biggrin And as I write this I am thinking of using that same Hinge to produce the "jealousies" together with the opening movement the movement of their stop (which rotates on the jealousy, however, should visually then be fixed to the frame)....
cool but why don't I stop for a little... instead of causing trouble for myself.... devilish
