Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Custom 3D Model being imported without texture » » » » Post: Re: Custom 3D Model being imported without texture |
Print at Oct 2, 2026, 3:52:54 PM |
| Posted by [email protected] at Mar 15, 2024, 4:18:13 PM |
Re: Custom 3D Model being imported without texture Hi Keet, Attached is the progress of my experiments on opening shutters, contained in the project. I don't know if this post is accurate, it's a discussion of models, movements and also the related pan3dview errors (which you have already fully explained to me. As indicated in the various levels of the project (one for each type of shutter), I still have two movement problems to solve. The first concerns moving the stop of "jealousy" in a coordinated way with its opening and closing. It would look a lot like a movement on a "Rail-to-Hinge" but it doesn't seem to work that way for me. I even tried to insert, as a test, an additional hinge on the rail thus set but the latter does not have any movement......am I wrong or is it not foreseen? The second would concern being able to open, as if it were a single block, several independent openings... but, honestly, I only hypothesized the possibility. Any kind of answer will be appreciated. Greetings https://www.mediafire.com/file/1ht6079mtqtl6uw/My_movable_shutters.rar/file |
Current timezone is GMT Oct 2, 2026, 3:52:54 PM |
