Print at Oct 2, 2026, 5:19:40 AM
Posted by Keet at Mar 18, 2024, 11:46:52 AM
Re: How to combine multiple levels
If you want to physically merge the 4 levels into a single tab you have to copy&paste from the levels into a new level. If that is ok you can remove the levels you copied from. Copying into a new level is safer than cut&paste into one of the levels because you only start removing levels after you have a complete merged level.
As Emmanuel mentioned you have to make sure all levels have the same elevation. You can copy&paste from a level with a different elevation but the furniture will get the level elevation where it is pasted.
11 levels is not that much and assuming you created separate levels for a reason I wouldn't bother with merging. Follow what Emmanuel said and you can see all levels together in the 3Dview.
