Print at Sep 23, 2026, 7:45:41 PM
Posted by Ollie_Jess at Mar 24, 2024, 12:45:46 AM
cool   Replacer Plugin 1.1
Hello Sweet Home 3D community, I developed the version 1.1. of the Replacer plugin, that does a simple task but can be useful in some cases, which is to replace furniture by another, copying certain properties of the furniture to replace to the replacement, but you can choose the ones that you want, like x, y, elevation, angle, height, width, depth, color, texture, etc. In addition, you can choose to replace groups of furniture as one object or replace every piece of furniture in the selected groups. You can also choose to replace only the selected furniture or all the furniture that matches the selected furniture.
This is the direct download and is also on SourceForge
The new improvements in version 1.1 are:
    • Added an option to transfer the brightness of the original object to the replacement.
    • Added an option that allows transfer light power, especially when both the original and replacement objects are light sources.
    • If the replacement object’s color or texture needs to be transferred, but the original object has default color and texture, the plugin will use the texture/color from the first material found or the first material modified by the user as the overall replacement color/texture.
    • Fixed a bug where replacing furniture within groups would cause the replacements to be placed outside the groups.
    • When selecting to replace all matching objects and choosing a group, the replacement will apply to that group and other groups with the same quantity and models of furniture.
    • Fixed other bugs regarding the replacement of groups and furniture within groups.
    • Source code within the plugin.
These are the steps for replace furniture with the plugin:
Before replace the furniture
Step 1
Step 2 - Choose "Replace Furniture..." in "Tools" menu option
Step 3
Step 4 - Select the replacement and configure the replace options
Success Message
Result - The replacement of the objects (in this case, the trees) has been done
Hope you like the plugin!
