Print at Sep 23, 2026, 4:59:00 AM
Posted by db4tech at May 29, 2010, 8:15:58 PM
Re: Sweet Home 3D 2.4
I can indeed confirm that the bug is now fixed. smile
db4tech
After further tests I and sorry to report the bug is still there but to a much smaller extent.
The catalog view still creeps down the the screen and across by only a small percentage, maybe about 5 pixels at a time. Watching the program open I would guess you programmed in a negative jump distance so as the windows try to reposition/jump it should end up back where is started. Is that how you did it?
If it is helpful I have attached a couple of files to show how far the windows move after 10 saves
Save 1 The reference point to gauge against.
Save 10 is the last save I did.
If I did more saves the windows would creep further but I thought 10 saves was enough to let you see what is still happening.
Sorry to report a bug sad
db4tech
Attachment save 1.sh3d (3277 bytes) (Download count: 589120)
Attachment save 10.sh3d (3310 bytes) (Download count: 589612)
