Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: running source code in eclipse » » » » Post: Re: running source code in eclipse |
Print at Sep 23, 2026, 3:56:08 PM |
| Posted by AvinashC at Apr 3, 2024, 9:58:18 AM |
Re: running source code in eclipse Hi all, I am trying to run the code from the git repo: https://github.com/SweetHome3D/SweetHome3D I am currently using the latest version Eclipse and jdk i am running the code with com.eteks.sweethome3d.SweetHome3DBootstrap as the main class with the arguments -classpath lib/java3d-1.6:<other_directories_or_jars> -Djava.library.path=lib/java3d-1.6/macosx -Djogamp.gluegen.UseTempJarCache=false as i am using mac i am getting the following errors 2024-04-03 14:26:14.327 java[1597:45750] WARNING: Secure coding is automatically enabled for restorable state! However, not on all supported macOS versions of this application. Opt-in to secure coding explicitly by implementing NSApplicationDelegate.applicationSupportsSecureRestorableState:. Exception in thread "main" java.lang.NoClassDefFoundError: javax/media/opengl/GLCapabilitiesChooser at java.base/java.lang.Class.forName0(Native Method) at java.base/java.lang.Class.forName(Class.java:375) at javax.media.j3d.Pipeline$1.run(Pipeline.java:162) at java.base/java.security.AccessController.doPrivileged(AccessController.java:318) at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:157) at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:965) at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:299) at javax.media.j3d.GraphicsConfigTemplate3D.isGraphicsConfigSupported(GraphicsConfigTemplate3D.java:351 ) at com.eteks.sweethome3d.j3d.Component3DManager.createGraphicsConfigurationTemplate3D(Component3DManage r.java:112) at com.eteks.sweethome3d.j3d.Component3DManager.<init>(Component3DManager.java:83) at com.eteks.sweethome3d.j3d.Component3DManager.getInstance(Component3DManager.java:160) at com.eteks.sweethome3d.SweetHome3D.addComponent3DRenderingErrorObserver(SweetHome3D.java:642) at com.eteks.sweethome3d.SweetHome3D.init(SweetHome3D.java:467) at com.eteks.sweethome3d.SweetHome3D.main(SweetHome3D.java:370) Caused by: java.lang.ClassNotFoundException: javax.media.opengl.GLCapabilitiesChooser at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:641) at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:188) at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:525) ... 14 more Could you please help with this |
Current timezone is GMT Sep 23, 2026, 3:56:08 PM |
