Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Generated ground broken on import, regenerate? » » » » Post: Re: Generated ground broken on import, regenerate? |
Print at Oct 13, 2026, 10:20:05 AM |
| Posted by Keet at Apr 5, 2024, 4:59:34 PM |
Re: Generated ground broken on import, regenerate? Your images(?) don't show, you probably posted the wrong URLs. From your description I suspect that you exported with the default option "Export all" for the object. It's annoying that the default export on enter is "Export all" because you almost never use that kind of export. You should use "Export selection" while you have all parts of the object selected (room, walls, furniture, etc.). "Export all" will include everything visible disregarding what is selected or not, including the full plan ground of the level which you usually don't want in your export. That is possibly the cause of the flickering (two textures are trying to paint in the same place). ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 13, 2026, 10:20:05 AM |
